Charging handheld
Delivers1234
Modesto, CA
Hi. I have a ft-2dr. If I leave it in cradle and use the adaptor is it okay to use a modified sine wave inverter? From the vechicle? For
Charging?
Charging?
I've never tried it.
However, I did have a modified sine wave inverter at a site at work and the switching power supply in a new network switch that we installed did not like it. Had to replace the inverter with a true sine wave model.
You could try it out, but if it doesn't work, or the wall wart gets really hot, it may be a problem.
Getting the ciggy lighter adapter, as k06jw said is a better solution. It's specifically designed for this application.
