Charging Time on BCD436HP
kstonecipher
Metamora, Illinois
I have plugged in my BCD436HP and it say Normal Charging. I have let it charge for 5 hours and it still says Normal Charging. When should I know that Charging is complete? Thanks
mikewazowski
Staff member
Forums Manager
Oot and Aboot
When it says Charging Complete.
Default Charging Time is 14 hours. You can change that by going into the Battery Options menu.
jaspence
Michigan
Charging time
The capacity in mah and hours of run time of your batteries will also determine the needed charging time.
NHdave
Southeast NH, USA
Also keep in mind this is a timed charging system, the state of the batteries has no bearing on when charging stops. When you plug it in it will charge for the amount of time you have set, meaning it may stop before your batteries are fully charged, or it will continue to charge even if your batteries reach a full charge.
kellykeeton
Snoqualmie, Wa
