Chattanooga Tennessee P25 system
#1
I just recently purchased a unified bcd536hp and I used the sentinel software to program the p25 system to my scanner. For some reason whenever I hear a transmission it comes in very patchy sounding and then clears up. It only clears up sometimes. Most transmissions can't even be made out.
Any help would be great!
kmi8dy
ARIZONA and MICHIGAN
#2
make sure you are putting in p25 phase 2 the old system was the motorola type 2 smart net. this system is being phased out. alss try useing your zip code to program and see if that works better. you could not have picked the hardest scanner to program ever, but anyway try useing your zip code to program the scanner and see what happens.
