Cheektowaga NY Tone outs and how to program
Wackyracer
Not new to scanners, new to the sds100, and tone outs.
What frequency is used with the 2 tones for Southline? is it the dispatch?
Also West Seneca companies?
lkas
Cheektowaga NY
they all use cheektowaga fire dispatch frequency with unique tones to each company
Wackyracer
I have that in the tone-out section of sentinel, but have yet to pick up anything. I'm sure it is operator error at this point and will have to find out what I'm doing wrong.
lkas
Cheektowaga NY
or are you looking for this:
BELLEVUE453.625000NFM1530.0672.0Off2secTone=7 / Volume=9Blue / Fast Blink
SOUTH LINE453.625000NFM1530.0871.0Off2secTone=7 / Volume=AutoRed / Fast Blink
CLEVELAND HILL453.625000NFM881.0582.1Off2secTone=7 / Volume=AutoRed / Fast Blink
DOYLE453.625000NFM1530.01036.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
FORKS453.625000NFM1530.0732.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
HY-VIEW453.625000NFM977.2645.7Off2secTone=7 / Volume=AutoBlue / Fast Blink
PINE HILL453.625000NFM1530.0799.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
RESCUE453.625000NFM1530.01130.0Off2secTone=7 / Volume=AutoRed / Fast Blink
SLOAN453.625000NFM1530.0950.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
U-CREST453.625000NFM1530.01232.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
ALDEN454.575000NFM2930.0799.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
BOWMANSVILLE454.575000NFM1744.0992.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
CRITTENDEN454.575000NFM2930.0950.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
LANCASTER VILLAGE454.575000NFM2930.01130.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
MILLGROVE454.575000NFM2930.0871.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
TOWN LINE454.575000NFM2930.0672.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
TWIN DISTRICT454.575000NFM2930.0732.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
DEPEW FIRE424.187500NFM643.01743.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
EAST SENECA423.987500NFM1669.0732.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
RESERVE423.987500NFM1669.0672.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
SENECA HOSE423.987500NFM977.2716.7Off2secTone=7 / Volume=AutoBlue / Fast Blink
UNION423.987500NFM1669.0871.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
VIGILANT423.987500FM1669.0950.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
WINCHESTER424.125000FM1669.0799.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
AKRON424.125000FM2688.01232.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
CLARENCE424.125000FM2688.0871.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
CLARENCE CENTER424.125000FM2688.0795.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
EAST AMHERST424.125000FM2688.0672.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
EGGERTSVILLE424.125000FM384.6473.2Off2secTone=7 / Volume=AutoBlue / Fast Blink
ELLICOTT CREEK424.125000FM2688.01130.0Off2secTone=7 / Volume=AutoBlue / Fast Blink
GETZVILLE424.125000FM346.7524.8Off2secTone=7 / Volume=AutoBlue / Fast Blink
HARRIS HILL424.125000FM716.7524.8Off2secTone=7 / Volume=AutoBlue / Fast Blink
lkas
Cheektowaga NY
you need to add the tones in sentinel and when you want to monitor it you select "tone-out for" then "tone out standby" from the menu. You can not as far as i know do regular scanning and monitor for tone outs at the same time.
Wackyracer
That is what I'm looking for and yes I am trying to monitor it while scanning.
What info does it supply? Is it a text message of the call?
lkas
Cheektowaga NY
no it is just the standard dispatch message. No different if you were listening to the freq. I tried it out for a day a while back but it was pretty boring not being able to monitor anything else
Wackyracer
Thanks, with many scanners that will not be a issue for me!
Wackyracer
I program Doyle tone-out in sentinel in the #2 spot, copy to the scanner, set tone-outs to standby and the scanner skips over Doyle.
I put Doyle in the #12 spot and it scans it. Any ideas?
CT
If I'm not mistaken, you guys are confused.
There are paging tones and squelch codes. They are two different things.
This explains how to set up Fire Tone Out.
And you can only monitor for Fire Tone Out OR scan. Not both.
Good luck!
