Chevy Blazer 97'
usswood
Terre Haute, IN
Trying to run a HOT and COLD off the battery and cant find a way inside the truck...any suggestions. Also is there an easier way than off the battery, something I could hook into or a 12v accessory Im missing somewhere. besides the cig lighter. Trying to hook up a FT-7800
Thank you
Wood
gambill1
pass thru
open the hood of your truck, and follow the hood release cable back to the fire wall. pull the gromet out of the fire wall and run your wires thru the space there. That is were I put my wires thru the fire wall at.
usswood
Terre Haute, IN
Thank you...I knew there had to be an easy way back under the dash...I will look at that direction...appriecate the comeback
73
n8emr
Depends if its an old body or new body GM started changing body styles, also is it a small s10 or 1500 blazer. If you remove the radiator overflow tank that is mounted up against the firewall on the passenger side you can usually find a grommet to go through.
money911
Delaware/Philadelphia
if your looking for something inside the truck already you can yank the head unit (stereo) out and take a multi meter up to it and find the 12v. the nice thing about that is you wont have to worry about turning it off it should get turned on when the truck is on and off when the truck is off.
hope that helped.
thesoundman
If you go to the battery, make sure to fuse the power wire, and use a grommet to protect it from the metal in the firewall. Also, instead of running a ground wire to the battery, it can be connected to metal frame/body inside the truck.
n8emr
hope that helped.
WHile you might find 12volts, your going to be hard pressed to find close to 10 amps of extra power. The wires feeding and head unit are not big enough to feed the head and another device. You need to go to the battery if at all possible.
usswood
Terre Haute, IN
Thank you...to all...yeah I was going off the Battery no matter what...positive and Negitive...there is an inline fuse on the hot and neg wires already...one good thing bout this rig is it has an auto off...but I wont be leaving it in the truck...I will take it in and out
scanbc780
Usually Lurking
Maricopa/Yavapai Counties, Arizona
I prefer a fuse under the hood on the positive just as it comes off the battery within 18" or less. If for some some wild reason there is a direct short somewhere in the engine compartment or where they come through the firewall you will still be safe from a wire fire. Its a small $5 investment that you may or may not ever need. Its better to never need it and have it than to wish you did.
You may have inline fuses in the cables already but when you come directly off the battery, you will want something in the engine compartment to protect the always hot run.
usswood
Terre Haute, IN
So ur saying in addition to the Hot and Neg Fuses already on the wires, I should use an additional fuse 2...these fuses are 12 inches from the terminal connectors
