Chickasaw Personal communications DMR Con+
Oklahoma City,OK
#1
I have been smashing my head through the keyboard trying to figure out the correct OTA channel numbering to tell DSDPlus.frequencies file to properly listen to this system https://www.radioreference.com/apps/db/?sid=7684
primarily site 357-5
Do any of you know the correct OTA frequencies and their channel numbers respectively?
DSDPlus need the correct OTA channel numbers and their frequencies to monitor it. It is trunked. I seen TG613 hop to different channels it doesn't know.
Oklahoma City,OK
#4
Can you share that?
DSDPlus.frequecies
;Chickasaw Personal Communications Site 357-5 Choctaw
Con+, 357, 5, 1, 454.0375, 0.0, 0 ; DCC = 1 CC
Con+, 357, 5, 3, 461.9000, 0.0, 0 ; DCC = 1 CC
Con+, 357, 5, 5, 454.2375, 0.0, 0 ; DCC = 1
Con+, 357, 5, 7, 463.5000, 0.0, 0 ; DCC = 1
Con+, 357, 5, 9, 461.3500, 0.0, 0 ; DCC = 1
;Chickasaw Personal Communications Site 357-7 Edmond
Con+, 357, 7, 1, 450.8500, 0.0, 0 ; DCC = 1 CC
Con+, 357, 7, 3, 461.8000, 0.0, 0 ; DCC = 1
Con+, 357, 7, 5, 464.3250, 0.0, 0 ; DCC = 1
Con+, 357, 7, 7, 454.3125, 0.0, 0 ; DCC = 1 CC
Con+, 357, 7, 9, 454.0125, 0.0, 0 ; DCC = 1
;Chickasaw Personal Communications Site 357-4 NewCastle
Con+, 357, 4, 1, 461.4750, 0.0, 0 ; DCC = 1
Con+, 357, 4, 3, 463.8000, 0.0, 0 ; DCC = 1
Con+, 357, 4, 5, 464.9500, 0.0. 0 ; DCC = 1
Con+, 357, 4, 7, 454.2125, 0.0, 0 ; DCC = 1 CC
Con+, 357, 4, 9, 463.9250, 0.0, 0 ; DCC = 1 CC
Each frequency has two time slots. Each time slot is considered a channel. All we need is the lower of the two then DSDPlus can figure it out. CC Channel Activity Display will always show a "?" in the CC line. that's normal.
Oklahoma City,OK
#5
I also want to add that on DMR Con+ systems even though they have 2 time slot per frequency, audio will come out both speakers other than left for slot 1 or right for slot 2 like conventional DMR. That's because they are considered as channels.
