Chimney cap interference
thom
New England
My Diamond discone is mounted on a 10 ft mast attached to a chimney mount . the chimney's aluminum cap is about 5 feet below the antenna. Is that a problem ?
jon_k
Fort Worth, Republic of Texas
The answer is no.
Unless it's in between the signals you want then there will be no problems.
Are there any specific concerns regarding the cap, or just a general "will it have an effect on my antennas field reception?"
thom
New England
re: Chimney Cap
Nothing specific, I thought all that metal up there near the antenna might not be a good thing.
jon_k
The distance from the antenna (5 feet is a lot) means that the antenna will not make any noticeable difference to your reception. Couldn't even be an effective ground plane like that.
Offtopic but, I always find it interesting when I see vehicles with 10 antennas on the roof about 3 inches apart. I always wonder if they end up making essentially a Yagi somehow with metal so close. I suppose not since they're all grounded... but it's funny to imagine.
thom
New England
I know the chimney thing isn't a great idea but the discone doesn't weigh much and the chimney is only 2 years old . We don't have fires in the fireplace either.
The metal in question is an aluminum cap attached top of the chimney to keep the weather & squirrels out .
