Baofeng CHIRP PL/DPL question
crownvic96
In CHIRP I'm building out a frequency list based off of the settings from this thread (pdf toward the bottom): 2021 nascar,trucks,xfinity
First time I've used CHIRP so I want to make sure I got the PL/DPL settings right.
1) For the PL Tones I set the Tone Mode to TSQL and use the Tone column.
2) For the DPL Tones I Set the Tone Mode to DTCS use the DTCS Code column and DTCS Pol is NN.
Did I get that right?
chief21
Western NC (Summer); Tampa Bay FL (Winter)
I haven't used CHIRP for quite a while, but I think for #1 (assuming that you really need to use TSQL rather than carrier), set the Tone Mode to TSQL and use the TSQL column to set the correct tone frequency.
#2 seems correct.
alcahuete
Southern California
That sounds accurate, yes.
Just keep in mind that to receive, you don't need any of those tones. You certainly can use them, but they are not necessary.
