City of Springfield PD/FD
n8dhw
Middletown, Ohio
#4
That's is up to you. Harris which now owns the EDACS and Provoice protocols has said they will stop support for both here in the near future. So I don't see how they could continue using that system without support from the manufacturer. Harris has been moving EDACS users to P25 like Miami County is doing. So it's only a matter of time that Springfield would follow suit.
Sent from my iPad using Tapatalk
German Township,Springfield, Ohio
#6
finances
what does a municipality do when the radio man. discontinues support yet the cannot afford to spend millions on a new system? I mean you and I try to conserve monies yet Government doesnt but how do they pay for a system if they don't have money? Seriously!!
wa8pyr
Technischer Guru
Moderator
Ohio
#7
If an agency failed to plan and budget for system upgrade or replacement knowing that their existing system would no longer be supported after a certain date, that's their own fault.
The End of Life for these systems was announced and has been well known for several years; both Motorola and Harris typically announce end of life 5-7 years before it actually happens. The End of Life announcements were made for Motorola Smartnet in 2010 (EOL 12/312018) and Harris EDACS in 2012 (EOL 12/31/2017).
After end of life, support is typically "best effort" meaning the service shops will fix it if they can, but if it can't be fixed, sorry about your luck.
#8
Thanks Tom so its like going to the junkyard to find the part that broke and hope somebody still has XYZ part. what a way to run a city.They just lost a measure here in Springfield to up the tax rate now threatening to close a fire house and pull some officers off the street. My thinking is if they have no money to run basics how do you pay millions for a new system , but someone was right, Marcs is only a down payment needed to get into business in comparison to building a new radio system.
wa8pyr
Technischer Guru
Moderator
Ohio
#9
MARCS would probably be a more viable option for Springfield. Buying the necessary radios and paying $20 a month per radio would be more attractive than having to come up with a few million all at once.
n8wel
Buckeye Toad
Springfield, Ohio
#11
Springfield
The city just recently posted a job opening for communications manager and not sure if this improve management yet. Also politics changed on SO and not sure if that will help on a joint dispatch center venture that never developed previously. The city is very backward on everything.
