clark county p25
camas wa
#1
i went to the clark county fair i of my favrite deputy september or october we well swictch to digital for clark county wa p25
thanks bears3312
camas wa
#2
clark co p25
thanks bears3312
looks like cresa green on the board does that mean there getting to switch or updateing channels
thanks bears3312
Beaver state
#3
You keep posting this ,but is there info about the system? is it the current system freqs? they changing to 700mhz as well?. More info would help a lot.
camas wa
#4
sorry my depty said sept or oct but he didnt tell what freq we are going on
bears3312 ps ill get more info for you
kd7kdc
Banned
#5
The reason CRESA was green is I went in and shortened up some of the channel description fields at the request of management.
camas wa
#7
thanks bears3312
my radio acting very strang the volume alof a sudden very low onthe clark county site is that my side or cresa
thanks bears3312
ps i have 396xt and 651 i mostly use my 396 xt simple to use
kd7kdc
Banned
#8
I don't know what talkgroups they plan on keeping when they go digital.
Object-oriented
#11
Clark County P25 is phase-2. Bears, haven't you been listening to it?
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 860
System Name : Clark County P25 Phase-2
WACN : BEE00
Tower Number (Decimal): 1-1
Tower Number (Hex) : T0101
Tower Description : Simulcast
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) :
Timestamp : Sat Oct 8 17:22:59 2016
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,935.01250,0.01250,-39.00000,"Confirmed",0.01250,1
05,935.01250,0.01250,-39.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-1401","a",859.76250,"00-1401",814.76250,0,0
"00-1429","a",859.93750,"00-1429",814.93750,0,0
"00-1561","a",860.76250,"00-1561",815.76250,0,0
"00-1589","c",860.93750,"00-1589",860.93750,1,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
102,"T0102",860,"00-1597",860.98750,""
106,"T0106",860,"00-1113",857.96250,""
Object-oriented
#18
when is the time line to switch do they have more frequencies
thanks bears 3312
I'd say the time line is probably pretty quick if the new system is on the air.
I can only reiterate what I stated above, "All I know of frequencies is what I posted". Try using your search function or running Pro96Com or similar decoding program.
camas wa
#19
clark county wa p25
ok thanks ill try that's that might help me
bears3312
