Clarke County VA Sheriff Help
EARMEL
Winchester, Virginia
Clarke County VA
I have a BCD996T Uniden Scanner and use the arc996 pro software & radio reference link to program it.
In the conventional list of public service frequencies 1 fire and 1 sheriff are p25. The fire p25 works fine when monitoring it, but the sheriff locks on I hear a fraction of what sounds like bad digital transmission then silence and the scanner continues to hold for a while then releases and continues normally.Do they use any other Frequencies?
Earmel
Macomb, Michigan
Clarke County VA
Earmel
If you look at the database for the sheriff notice it says some encryption so that is why you hear that funny worbling sound. More than likely if you hear that all the time you will not be able to hear them.
154.04750 WQDF982 RM 351 NAC SHERIFF Sheriff (some encryption) P25 Law Dispatch
The only other suggestion maybe is to put in the Sheriff interop: 39.54000 KJH229 BM 100.0 PL SIRS Sheriff Statewide Interdepartmental Radio System (SIRS) - Clarke County Units FM Interop
