Classic Scanners (Showcase)
Omega-TI
Ω
Washington State
I thought it might be nice if we had a showcase for "Classic Scanners" as newer is not always better (for every application). So, if you have a "Classic Scanner" that you think others might like, post a video here! I'll start this thread off with the Uniden Bearcat 800xlt.
trentbob
W3BUX- Bucks County, PA
Nice video, that radio in that condition is one in a million. Very difficult to find in that good of shape with a display that works and a receiver that still receives.
Unfortunately even in rural areas there are very few places left that are completely conventional, non trunking. I know places like that exist but not in my part of the world. I certainly enjoyed those days when I was a kid in the 60s... I especially liked VHF low simplex... 33MHz, 39 MHz and 45 MHz.
So this is in the Uniden Tavern so that eliminates the majority of the real all time classic scanners. They were made by companies that existed before Uniden was in the scanner business prior to 1983 when they bought the Electra company in Cumberland Indiana and the "Bearcat" name. By that time all of the real classic programmable radios were already developed and in service. Sticking with just Bearcat scanners we eliminate so many great Classics made by GRE for RadioShack, Regency, AOR... Ect.
First of all when I entered the hobby as a kid we didn't have scanners. This is what I used.
Technically my first scanner which was an all-time classic for so many folks here was the Bearcat lll, I used the VHF high/ low model.
We were actually in the space age at that time and this was Space Age.
My all-time favorite classic was my first programmable scanner, the Bearcat 101.
$399.99 at Lafayette Electronics in 1975, my first year out of college. That would be pushing a thousand bucks in today's world and worth every penny.
Then we had the Bearcat 210 which was keyboard programmable and it was after that Uniden took over Electra Co. and continued the 200 series... of course then came the classic Uniden trunktrackers.
Honorable mention would have to be given to 2 great classics introduced together in 2003, the GRE RS Pro 96 and the Uniden bc250d, the first handheld digital scanners.
Omega-TI
Ω
Washington State
Thanks! You know, I have no objection to having this thread moved to a more generic section of RR if that'll bring in more scanners.
Looking at that Bearcat 101, I'm curious about the programming method. I might have to look up some documentation on it after I get home from work today. Thanks for sharing some great memories.
RichardKramer
Reading, PA
The BC101 to program: Came with a booklet of freqs; manually stepped to the channel you wanted to program; you pushed the ready button down, the freq in the booklet listed which panel switches to put down or up, pushed the enter button to enter the freq into a channel position.
trentbob
It came with a programming booklet. You would pick the frequency you wanted and it would have a series of numbers from 1 to 16 next to the frequency. You would lift the tabs in sequence of the number of the code attached to the frequency and then drop the slide switch on the right lower part of the radio and it would enter the frequency in the slot that you chose. I always kept Channel 16 as The Weather Channel and kept that slide switch off.
It was a marvelous radio, no crystals. Great reception. It was AC only but I had a converter on the floor behind the driver seat. I just had to reach around and throw the slide switch and it worked great in the car.
bubbablitz
Too young and too poor to have a video of my first “Classic” scanner so you’ll have to picture it in your head. It was a Realistic Pro-21, a VHF/UHF crystal controlled, 4 channel handheld. It was in 1980, I was in high school working part time at night and on Saturdays. It cost me 129.99 plus tax, if I can recall correctly, not including the cost of the crystals, which I believe were five bucks each. Back then, you went to your local Radio Shack, the guy behind the counter pulled out a plastic fishing tackle type of organizer box, with several different Public Safety Agency crystals. Growing up in Los Angeles, within the Rampart district, channels 1 and 2 were the LAPD transmit/receive frequencies on VHF high, 2 channel simplex I believe it is called, but I could be wrong. Channel 3 was “Tac 2” car-to-car, (think Adam-12). Channel 4 was a suggestion by the salesman, it was the FBI downtown office on a UHF repeater, probably in the 406-420 Mhz 37387E49-CA9A-4DC7-9ACD-F0E023F4DCA2.pngband. Those conversations were very clandestine, with the agents never mentioning physical addresses or locations, describing everything by landmarks and using code words so it was pretty tough, and boring, to actually figure out what in the heck they were doing. This scanner had the old screw base connector, before BNC. I would take a ground plane radial from a 1/4 wave CB antenna and screw it in there, and it increased the listening range by several miles. I hope this brought back some memories to someone.
trentbob
We replied at exactly the same time :LOL:
trentbob
Yes we did! Did your converter get pretty warm? I don't remember the model I had; but it did get warm under the dash.
Yeah it would get pretty warm. It was quite large, bigger than a breadbox and that's why I put it on the floor behind the driver seat. I was always careful to start the car first and have the radio off before throwing the big toggle switch. I would also turn the radio off before throwing the big toggle switch off.
mass-man
trying to retire...
Parker Co., TX
😃...my local NWS station is still in Ch16 in my BC 101!
icemantim8
Colorado
Hi RickH. Love that link. Thank you. I had a Sears and a Montgomery Wards scanner....lol....and of course the Radio Shack Patrolman series....OMG...I am old.....haha.
trentbob
My Sears 5 band programmable scanner (made by SBE). Programmed with slide-in 16 position punch cards. Best sounding audio of any scanner I've owned.
Now that is a rare classic, what was it, the Regency Whamo 10 that had the metal combs that you broke the teeth off and then plugged them in like they were crystals? Later they came out with an actual frequency selector. Man these are classics from the mid-70s.
Omega-TI
Ω
Washington State
I love the look of that scanner and the wood case is awesome. I wish more radios made today had wood enclosures.
I wonder if anyone has made 3D printed replacement punchcards for that model?
n2pqq
Still have a BC101 remember using the software below to make it easier to program
If I check around I may still have a BC Two Four Thin scan handheld by Bearcat
came across this video
tvengr
Well Known Member
Baltimore County, MD
We had several 800XLT's in our newsroom. A dim display was a common problem. Replacing a couple of electrolytic capacitors restored the display.
trentbob
Yep, we also had them in our newsroom also, they were purchased for the New Jersey State Police analog trunked 800 MHz system. I was just a lowly staffer at that time and stayed out of it and of course they didn't work for the state police system so the chief photographer just put in all of the 800 MHz frequencies and it was hit or miss, the bosses really never knew LOL.
