Cleveland County NC
WeBeCinYa
NC
#1
I wanted to see if someone could set up Shelby PD from Cleveland County, NC on broadcastify. I am an avid listener to the entire system and see that someone has Fire & EMS up on the link below, but Shelby police is missing but on the same system.
https://www.broadcastify.com/listen/feed/27707/web
Shelby Talkgroups
DEC HEX Mode Alpha Tag Description Tag
101 065 D Shelby PD Disp Police 1 Dispatch Law Dispatch
103 067 D Shelby PD Disp 2 Police 2 Dispatch Law Tac
https://www.radioreference.com/apps/db/?sid=6122
Brunswick County, NC
#2
You may want to consider moving this question over to the NC Forum. Might get a response from the current feed provider and/or another member in that area. Just a thought. You would use the red triangle in the upper right corner of your post to have the question moved.
