Clinton County Fire Question
W9NES
Indianapolis,Indiana
Can any of our Clinton County RR Members provide a answer for me on this question.Last Night Tuesday 12-21-2010 I was hearing a major Fire somewhere in Clinton County and heard Tanker 132.Which Fire Department has Tanker 132? Also the Wiki for Clinton County Fire did not have this infomation.Can anyone provide the infomation I need.Thank You. Very Best Reguards,Tim DeLong W9NES/ GMRS KAF3207/*Monitoring all of Metro Indianapolis/Marion County and all of Central Indiana*
GTO_04
Noblesville, IN
It is probably one of the smaller VFDs in the county, like Kirklin or Michigantown. There is scant information available on the apparatus for those departments. I checked Indianafiretrucks.com and found nothing at all on that tanker.
GTO_04
W9NES
Tanks GTO O4 for your post.I also checked that web site before posting my question and looked at all th Fire Departments in Clinton and counties around Clinton County and I found no infomation on Tanker 132.
GTO_04
Noblesville, IN
I wish I could have been of more help, but I don't monitor Clinton County very much. Did you hear this on SAFE-T or one of the Clinton Co. VHF fire frequencies?
GTO_04
W9NES
GTO O4 Thanks for your post.I heard a Major Fire in Clinton County on Tuesday 12-21-2010 and I heard the entire operation on Clinton County thru the Boone County Tower Site and this was on SAFE-T.Tried doing a search for Michigantown or Kirkland fire and did not find any web sites.Can anyone up in that area help me out on which Fire Department has Tanker 132? Thanks
KidClerk
Newton Co., Indiana
possible numbering system
I'm not sure if this could be the case, but in some counties, the first number of all fire units relates back to their assigned FDID number. This is a statewide numbering system that is used in reporting our fire data to the state. The first digits are the county's alphabetical number that used to be prevalent on our license plates. The next three digits are the department identifier, also usually alphabetical. Here in Newton County, my department (Brook VFD) is 56-001. All of our helmet and truck numbers correspond with this system. Helmet numbers would be 56-101, 102, 103, etc. Trucks are numbered the same way, 107, 112, 113, etc. Goodland VFD is 56-002 and they number everything beginning with a 2. The exception to this rule here is that EMA many years ago was assigned the 600 series of numbers throughout the state, so Morocco, 56-006 actually uses the 700 series of numbers and our EMA has the 600's.
Here is a link to all FDID numbers for Indiana fire departments. Now, do not assume every county is numbered in this manner. I'm just saying its a possible method. Some counties do not have any uniform numbering, such as my neighbors in Jasper County. They simply use "Pump 3" or "Tanker 1" or "Brush 2" for each department. But since each department is dispatched on a different frequency, it doesn't cause too much confusion. When you have a county-wide dispatch frequency or central dispatching, the dispatchers have to have a way to distinguish between departments and this is one possible numbering method.
IF...and I said IF...this is how Clinton County were to number their departments, the truck in question would have been from Perry Twp. VFD in Colfax. However, the news reports I looked up while posting this do not list that department as responding to the fire I think Tim is referring to in Michigantown.
http://www.in.gov/dhs/files/firedepts.pdf
W9NES
Thanks Kyle for your post and info.Perry Twp in Clinton County according to Indiana Fire Trucks.com shows Perry Twp as Station 12.Does anyone have any infomation on Michigantown or Kirkland Fire Department as I have done a search and cannot come up with a web site for pictures.If anyone can provide a link that would be great.Thank You, Tim DeLong W9NES/GMRS KAF3207/*Monitoring all of Metro Indianapolis/Marion County and all of Central Indiana* Sent from my Laptop Computer*
W9NES
retpactiv,Where is Forest?Never heard of that Fire Department in Clinton County.Can you send me a link on there Fire Department and their Equipment.Indiana Fire Trucks.com does not have a posting for them under Clinton County.Thank You.
retroactiv
Chesterfield, IN USA
I believe Forest only has a Tanker and an Engine, it's a very sparely populated area mostly farm ground in North East Clinton County.
They are listed on the Clinton County Wiki but I don't feel comfortable enough listing there equipment because I'm not 100% sure.
