I have a Pro-651 handheld and an old Uniden desktop scanner.
I program in the same 9 local analog channels and let them scan.
When a transmission is received the Uniden Desktop picks it up and you hear the beginning of the transmission, the Pro-651 picks it up later in the transmission and the beginning is never received on the pro-651.
The 651 will stop on the channel but wont play sound until late.
I also tested this with my BC246t and the 2 unidens pick the full transmission up but the Pro-651 comes in late.
The bc246t wasn't using an antenna and the desktop uniden is using the stock telescoping antenna. The pro-651 uses either the stock rubber ducky or a SpectrumForce Wideband Antenna
Example: the Uniden scanners received "Station 99 this is an alert" while the Pro-651 receives "is an alert" or just "alert"
How can I fix my pro-651?
