I have my BC125AT set to Close Call Only with Scan Hits on. 10 hits are suppose to be stored in a bank called Close Call Hits. I can't find any explanation on how to access that bank. Can someone help with this?
How do you access this bank??
FNC + scroll to the bank.
That's not working.
I'm in Close Call Only mode and is scanning. If I do as you say, nothing happens.That is how I do it.
To be clear, you MUST be in regular scan mode before you push Hold.You would need to be in hold mode to scroll to the bank. Func: scroll will let you select each bank. when you highlight the close call bank at the bottom, press func again. you should then be able to scroll through that bank with the knob on top
