Yes, the antennas are too close and will interact with each other. The impedence of one will be altered by the other although this may not be the most important factor for wideband antennas that are not particularly well impdedence-matched at every frequency anyway.
One antenna will affect the "radiation pattern" of the other which can create nulls which cause loss of signal in some directions. Conversely it might help in some cases but it is not very predicatable. Precise spacing of identical antennas with control of the phasing between the two (through the coax) can create some interesting "patterns" such as cardiods (with a null), figure-8 etc., but not with two very different antennas.
If possible, separate them by several wavelengths at the lowest frequency. At VHF high-band, a wavelength is roughly 6 feet. It's not always feasible, just do what you can.
Dave
