CLS1410 charging problem
K2NEC
NA
I bought a bunch of CLS radios for a friend of mine and they seem to have issues charging. Whenever they are in the charger (6 bay charger) it takes a lot of moving around and convincing for them to charge. And when they finally do, most of them just start flashing red rapidly. I've tried with and without the holsters getting pretty much the same results. I've used these radios one or twice before and I don't remember them having this much of a problem. Is there a trick or something I'm missing to get these to charge properly? Is it possible the batteries are going bad? I did get them second hand. Is this also a common problem with CLS radios?
Tech21
If you set the battery in the charge does it go amber as if it is reconditioning the battery? If so, let them recondition. If they just go to flashing red, the batteries are bad. Look at the date code on the battery.
K2NEC
NA
These are CLS business radios, they do not recondition. Amber means "waiting to charge"
EDIT:
And they don't stay flashing red. I got some of them to go steady red and even green. But if you move them even a hair, it's like they lose connection with the charger and they go flashing red again.
K2NEC
NA
In the end I managed to get all the batteries to charge overnight and it seemed like they all held a charge. All radios charged to green. I'll see if my friend has any problems with them overall.
