cm 200d
rich1125
i have a 4 channel cm200d and im having problems transmitting , so when i transmit i can talk after that all i get is a tone then a flashing green light then it does not transmit agian any ideas it just happened today.
Motoballa
911 Dispatcher
North Texas
Different radio but same problem for me. I don't know if the CM200D offers some type password option, if it does then make sure you left that blank. My CP200D had one (despite it not having a keypad to enter a password) and I accidentally put something there and after writing it did the same thing, I for sure thought I bricked it! :p
See if you did and let us know. Hopefully someone has a for sure answer if this isn't it.
bharvey2
I'm not real familiar with that radio (not a Moto guy) but what comes to mind is that the transmit frequency is outside of the radio's typical transmit range of frequencies. Did you recently reprogram the radio?
rich1125
no it just started acting up dont know what happen only way to talk is go channel up channel down to transmit .
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Make sure your admit criteria is set to Always or Polite to own PL or Color Code..... You may be getting slammed with a co-channel user detection measure. Commonly called Busy channel Lock Out...... TT
