CM200D programming issues
gthomas40
Waukesha, WI
So we got 2 new CM200D radios recently. I tried to program them using the CPS that we already had and it says codeplug not supported. Is there a way to roll the firmware back or something so the software that we already have will work? Or am I stuck paying the $169 to buy the current CPS from Motorola? I hate having to use different software for each radio.
If I do upgrade the software will it have backwards compatibility for my older radios or will I have to use 2 separate versions?
K2NEC
NA
Not with anything that can be discussed on this website. You would need to buy the latest CPS or find someone that has it that can program it for you.
Newer CPS will work with older firmware but newer firmware will not work with older CPS
gthomas40
Waukesha, WI
What do you mean by not with anything that can be discussed on this website? Is that in reference to the software or rolling back the firmware? I am not asking for details I am just trying to figure out which topic your statement pertains to for my understanding.
As for the software, Motorola Solutions had submitted a ticket to fix my account. I guess it was set up with all the wrong settings and now that I can get to the new site I still can't order anything new yet... Still waiting on my "official" quote to arrive in my email.
K2NEC
NA
It's the software that might allow you to rollback the firmware. While not guaranteed, it's more of a 50/50 chance.
Motorola likes to take their time when it comes to that. You could be waiting a bit for that to get sorted out.
gthomas40
Waukesha, WI
Gotcha. Hopefully they don't release new versions of the software very often so I am not doing this again next time we buy another radio. :)
RadioGuy7268
PA
If you're buying new radios from a legit source - have you checked the price to have them program the radio for you? It should be super easy if you just email them with an existing codeplug. Many shops would include Free programming with new radio purchases, or charge just a minimal amount to put in a few basic channels. More exotic programming can cost more if someone needs to build a new codeplug for you, but it sounds like you've already got a working sample that could be copied over.
gthomas40
Waukesha, WI
The issue is the radios where preprogrammed for our main facility and they needed to be programmed for another operation we have at that location that uses different frequencies. I did end up calling and getting the CPS 2.11 and it is good to go now. I had to ignore the warnings about cloning from an old codeplug to a new codeplug but for now it is working. This is just another reason I hate dealing with our Motorola mobile radios vs our Kenwood HTs.
