cm200d
asstchief2651
I am installing a CM200D MOTOTRBO radio bought programing cord through amazon still having problems programing an error comes up in little window
it says unable to connect check see if compatable programming cable is used any help would greatly be appreciated thank you.
RadioGuy7268
PA
You need to be using MotoTrbo CPS to program the CM200d.
Did you buy the radio new or used? Do you know what version of CPS it was using? MotoTrbo has the older CPS16 build 828 (probably would work for an older used radio) or new units might require the latest version of CPS 2.0
You need to supply more information if you want specific help beyond that.
asstchief2651
radio is for police dept, ver 3 R01.011.300000, no on cps it was using. where would i get that software. i do have mototrbo software
