CMD 750 Streaming audio
New York, NY
#5
As with most Motorola mobiles -- NEVER use Pin 1 or Pin 16 unless attaching an ACTUAL speaker. Grounding or even accidentally loading pin 1 or 16 in an incorrect manner can release the life-time supply of smoke from the audio amplifier IC.
New Orleans region
#6
Be aware that there is a DC bias voltage on the filtered RX audio pin. You might have to add a 1.0 uf capacitor in series with the connection to block the DC voltage coming from the Motorola radio if your device being fed doesn't provide for it.
canthonysmith
Arkansas
#8
How would you recommend obtaining audio from a mobile for streaming?
SteveC0625
Northville, NY (Fulton County)
#10
This entire thread is devoted to doing exactly that. The answer to your question is contained in the previous posts.
For a CDM with the 20 pin accessory connector, please re-read Post #3 and pick the "Buy Your Own".
If you have a Motorola with the 16 pin accessory connector, the same seller offers the same kit with a 16 pin mating connector. It's his cable #61.
It doesn't get any simpler than this.
#12
Pin 11 - Fixed level RX audio - Programmed for filtered audio
Pin 7 - Ground
Do NOT use pins 1 and 16 !
