CMD1250 Bootstrap Mode
SpugEddy
Camden County South Jersey
Does anybody know how to put the CDM1250 mobile
into bootstrap mode? Very little on the net on how to do
this and I have tried everything I was able to find with no results.
Also, is there a manual way of doing it with a combination
of buttons on the front panel?
I'd really appreciate any help on this.
Thank you
K2NEC
5F6
Are you talking about service mode? Press the bottom left button 5 times immediately after power up
SpugEddy
Bootstrap mode so I can flash the codeplug. I screwed something
up and (although the radio works), I can not write to radio
nor can I read from radio.
K2NEC
5F6
You mean bootloader?
No such thing on the CDM AFAIK
SpugEddy
No I uploaded the changed codeplug into the radio using
the same computer as I use for my CDM1550. The software
had been hex edited to open the 450 - 520 frequency range.
All I did was change that to 440 - 510 on the 1250 and now
cannot get back into the radio. like i said, the radio works
but now unprogrammable.
*EDIT*.. I should mention that i thought I had saved the original
codeplug in 2 different spots (as I always do). Apparently
I missed that step and now I'm paying for it.
K2NEC
5F6
What's the model number of your radio? I might be able to get you a codeplug force in.
N1GTL
CT
You need a flash adapter to upgrade firmware and put it into bootstrap mode. You'll need a flash adapter which can be bought or built. You also need the firmware update file. It's been a while but it is R05.10.02 or something close. Here is a write up I did 11 years ago. I'm not sure if the diagram links still work but Google is your friend.
CDM1250 firmware through mic jack? - Batboard
SpugEddy
OK... To answer both, AAM25SKD9AA2AN
Radio says Tanapa # IMUE6025A
Radio reads: IMUE6025A
Here is what I've tried so far:
Flash Upgrade R05.10.04
I made a cable for front panel RJ45 jack
Using the RIB: Pin 1 RIB to Pin 5 RJ45 (GND)
Pin 15 RIB to Pin 2 RJ45 (BUS+)
Jumper between 2 and 8 on RJ45 side = no joy
Jumper between 3 and 8 on RJ45 side = no joy
When using Upgrade R05.10.04:
Radio will go into program mode but on the reboot
(according to the instructions) it just goes back to
a normal boot. Never goes into bootstrap mode
K2NEC
5F6
I have the codeplug for that if you want to force it into the radio...
SpugEddy
Thank you for the replies and for your input, guys.
This project has completed.
BTW.... anybody looking for a nice paper weight? It looks just
like a (coincidentally) CDM1250.
N1GTL
CT
Why? Didn't you read the post? You're cable is wrong. Sorry you lost the radio.
SpugEddy
OK... I had a friend on the phone last night getting some
help and input from him. I tried something and the radio
went totally dead. Would not power on and no display.
Being the type who does not admit defeat easily, I tried
putting 12v to Pin 10 on the accessory connector. When
I did that, the display showed EEPRM CS ERROR. I undid
last night's change, crossed my fingers and hit the write to
radio and amazingly it worked.
So, now I am back where we left off and I am now trying
to do what the post says. I will update. Thank you so much
for all of the help.
N1GTL
CT
Google "HLN9742B PINOUT" That's the adapter you need to make to put the radio into boot strap mode.
N1GTL
CT
Just curious....what version of firmware are you on? Is there a specific firmware update that solves an issue you are having? Not judging, just curious.
SpugEddy
N1GTL.... Not sure what the firmware version is, BUT this issue
has been resolved and it was not firmware related.
I'll explain for future reference in the event somebody else
has the same kind of issue.
I was using (at the risk of some unfriendly remarks) CHIRP software (with the waris.py module)
to be able to go out of band with the radio. I wanted 440-510
instead of the stock 450-520. The CHIRP software has has about 8 or 10
fields labeled something like "Trunking bit 0" enable/disable then
"Trunking bit 1" etc. It also has "Conventional bit 0" and so on.
Since the radio is NOT a trunking radio I had turned off the
trunking bits. THIS IS WHERE THE PROBLEMS CAME IN
Last night I sat in deep thought for about 20 minutes and
decided to "give my brainstorm a shot"
I booted up CHIRP read the radio, went in and enabled
ALL of the "Trunking bit" fields. I prayed to the Moto Gods
and hit write to radio and it took it just fine.
Now, the real test. Would it read and write using the CPS software.
Again I prayed to the Moto Gods and hit read........ BINGO
read the radio with no errors. I hit the write to radio and
BINGO again.
Problem solved issue closed and radio is working perfect
from 440-510. Thank you everybody for your help and input
As suggested by N1GTL, I did purchase the HLN9742B module,
and all the gender changers and adapters necessary. At least I
have them now for future use. Thank you N1GTL for that suggestion
K2NEC
5F6
You could have just done an out of band mod for it and not risked with the CHIRP software. All it takes is a simple hex edit and that's it. But all is well and ends well. Glad you have it working again
