cnyicc onondaga county
onondaga cty,New York
#1
I noticed the talkgroups were updated today for intra/intercounty,can you tell me what frequencies to use in these talk groups? do I use onon. cty freq or the ones for each individual countys. Do these replace all the nims channels?
GTR8000
Well Known Member
BEE00
#2
The talkgroups that were labeled NIMS (63-71) have been re-purposed.
Each county has two countywide Events talkgroups, which would likely only be broadcast on that county's simulcast cell. The All County talkgroup would likely be broadcast across all four cells.
sav1350
Capital District, NY
#3
I can confirm that 63-71 are all being broadcast on the Onondaga system. I have seen joins and calls via UniTrunker on them. However, since Onondaga is the master site, that may not be true for the other counties. Most of the other counties have been carrying the primary dispatch channels for other counties. So, perhaps it may be true in the other counties. I'm not in a good place to get reception from any of the other counties to say one way or the other.
