Coast Guard Frequencies for NC?
Bozeman, MT
#1
Does anyone know then for the NC area? Especially for Fort Macon, near Morehead or any in Wilmington.
Thanks, for any help, I am still new to RR but already it has been a great site.
West Central Florida
#2
Here is a list I have and it should be enough to get you started on the Coast Guard
Channel Frequency Mode Description
01A 156.050 FM Port Operations
05A 156.250 FM Port Operations
06 156.300 FM Intership Safty
07A 156.300 FM Commercial
08 156.400 FM Commercial
09 156.450 FM Boater Calling
10 156.500 FM Commercial
11 156.550 FM Commercial
12 156.600 FM Port Operations
13 156.650 FM Bridge to Bridge
14 156.700 FM Port Operations
15 156.450 FM Environmental
16 156.800 FM Calling Distress
17 156.850 FM State Control
18 156.900 FM Commercial
19 156.950 FM Commercial
20A 157.000 FM Intership
20 161.600 FM Port Operations
21A 157.050 FM Coast Guard Cutters & Helicopter
22A 157.100 FM Coast Guard Liaison and Maritime Safety Information Broadcasts
23A 157.150 FM Coast Guard
24 161.800 FM Public Correspondence
25 161.850 FM Public Correspondence
26 161.900 FM Public Correspondence
27 161.950 FM Public Correspondence
28 162.000 FM Public Correspondence
63 156.175 FM Port Operations
65 156.275 FM Port Operations
66 156.325 FM Port Operations
67 156.375 FM Commercial/Intership Saftey
68 156.425 FM Non-Commercial
69 156.475 FM Non-Commercial
70 156.525 FM Digital Selective Calling
71 156.575 FM Non-Commercial
72 156.625 FM Intership Only
73 156.675 FM Port Operations
74 156.725 FM Port Operations
77 156.875 FM Intership Only
78 156.925 FM Sea-Tow
79 156.975 FM Commercial
80 157.025 FM Commercial
81 157.075 FM US Goverment
82 157.125 FM US Goverment
83 157.175 FM Coast Guard Only
84 157.225 FM Public Correspondence
85 157.275 FM Public Correspondence
86 157.325 FM Public Correspondence
AIS 1 161.975 FM Automatic Identification System
AIS 2 162.025 FM Automatic Identification System
88 157.425 FM Commercial
Fairhaven MA / San Jose CA / Kihei HI
#4
Channels 16, 21 and 22 are the most likely ones for the Coast Guard to show up on.
16 is the hailing and distress channel and is the one used for Mayday calls. 21 and 22 and also 23 are working channels for the Coast Guard. It seems like 21 and 22 are the more common working channels.
Coast Guard auxilliary uses 83 in some areas.
Bozeman, MT
#7
Thank you guys, and sorry ScanXO, I am still relatively new to this site, from now on I will try to rely on the database and wiki more, but thanks for the help anyway.
Carmichael CA
#10
Hey EP don't know if ya have a receiver that covers HF ( shortwave ) but if so, ya might wanna check
out the USCG frequencies by "googling" or whatever you use to search.
Many times, especially during disasters such as the Gulf Oil mess off Louisiana, ya may hear some interesting communications. As far as SW is concerned, there is a bunchagoodinfo in the WIKI section
of this forum,,,sometimes I forget to look there first. A little warning, tho..this scanning/swling just may be addicting!!....you'll find out. Good hunting and welcome!!
Bozeman, MT
#12
No I do not, but I do have a medium range VHF/UHF/800Mz antenna, the ones with the scanners are not that good. Thanks and I will have to try that some time. And I know what you mean about scanning being addicting, I have been at it for almost four years now, but boy is it fun :), thanks again.
O, and WA1ATA thank you for the other frequency, I am adding to my scanner right now.
Bozeman, MT
#13
Also thank you for the welcome FLA2760, and I am not going to get into a debate, I only want to learn more from this site and add to it what I know, so far it has been great.
Hudson Valley
#14
EP204 Also i notice someone mentioned channel 83 for Coast Guard Auxiliary, you might want to google for official Coast Guard Auxiliary non-marine VHF channels which sometimes or most often are working channels for the Coast Guard Auxiliary and will most likely be working channels in case of an disaster. Also each location is different with them, 1st District Southern each division has there own set of frequencies and repeaters with also main tactical channels also.
Welcome to RR and good luck on the maritime listening
Taxachusetts
#15
As Kenny already pointed out, use the RR WIKI, they are already listed there. There is Only ONE Repeater Pair for the CG Aux now.
hill
Middle River, MD
#16
I don’t which of the channels that Sector North Carolina uses. The main CG channels are 21A(157.050 MHz), 23A(157.150 MHz) and 83A(157.175 MHz). You should put all in your scanner, since they rotate them between Sectors to cut interference with other nearby Sectors. Also anyone can be active during large events. In some areas channel 81A(157.075 MHz) is the mix also. Much of the radio traffic that used to be carried on the CG VHF-FM marine channels is now on the CG VHF and UHF LMR nets. The CG LMR are mainly P25 encrypted.
Bozeman, MT
#17
I have looked in the wiki and the DB, and many thanks, Mbk127k, ecps92, hill, I will add those.
So far the freqs. clawhammer posted are what I am picking the CG on. Thank You all for info.
