TRX-1: Coast Guard P25
waltmapb
Merritt Island, FL
#1
I am using the software to import the Coast Guard P25 VHF nets and assign to a scanlist.
When I create the scanlist the system always shows as analog although they should be digital P25 with a NAC of 193.
It seems that a conventional scanlist will only show the system as analog and it cannot be changed.
Since the objects are NFM and digital will they scan properly even though the system label in the scan list is analog?
waltmapb
Merritt Island, FL
#5
So what mode should be selected for a P25 conventional channel ?
the choices in Easy Scan are:
AM
FM
NFM
AUTO
DMR
Or does it even matter?
