What if he stripped and exposed a 10" length at the top end?
And, and then he could solder some radials to the shield..... Oh, wait, that's a ground plane. Never mind....Well,he could fashion the coaxial cable into a crude "leaky-ax" antenna,by simply exposing the center conductor at a length close to the wavelength of his choice.
n9zas
The coax bazooka is really hard to beat, I doub't that a J pole would do much better. Just strip about 23 inches of the outer insulation off, fold back the braid on the coax, leave the center insulation on and trim it to about 18.5 inches in length. Suspend it from an overhead support with a piece of string and you are ready to listen
Right you are, and did you notice that you are at 666 posts? :twisted:
n9zas
