How do I clean this mess up? Need to have a better set up before winter starts up around Oct/Nov.
I have the following coming into the house.
2 scanner base antennas. 1 can be switched out for anything. It's sitting on a 30 ft pole on the back deck. The main discone is on the roof.
1 CB base antenna.
1 shortwave/hf end fed wire antenna for SDR listening.
1 FlightAware feeder.
I have seen frost on these connections in the winter time. That is not good. Also this room was an unfinished room. It has been completely renovated and good to go. Just need to clean up the cable mess coming in.
1 CB base antenna.
