I have several antennas on a tower that have coax ran into the building. What would be the best way to trace the coax to figure out which antenna it goes too without climbing the tower? Any suggestions are appreciated thanks.
SIf they're all at the same height and frequency then not sure how you're going to do that.
If they're at different heights, than a DTF measurement should give you an idea or if they're different bands, a sweep should help.
S
They are all different heights. Some are UHF 400mhz, some VHF 150mhz and ive got a couple 700-800mhz Yagis as well.
There are some tone generators/probes (a la the Telco industry) that can be used with coax. You'd have to take the antennas/coax out of service to test. Also you'd have to start at the base of the coax (no splitters, combiners, etc) The type of antenna connected to the tower end of the coax would likely affect how well this methods works though. The analyzer would be the better bet.
A toner would work, however the OP didn't want to climb the tower.
TDR/or the NanoVNA and check the resonance of the antenna is the easy way to do this without climbing the tower.
Perfect world would be a tower map with the coax cables "phase taped" and identified after install.
If by by chance his antennas were 1/4w GP / with no matching circuitry he might be able to get by without a tower climb. I forget we were in the industrial forum so these are more likely to be cellular sector antennas or something similar.
An antenna analyzer used inside the building should tell you what band the antenna is by showing a low VSWR within its operating band.
Couple that with a DTF sweep and you should be able to ID the antennas and feedlines with reasonable accuracy.
As said hook up a analyzer and run return loss and DTF. That will at least give you a starting point. Sometimes it will come down to a climber or a drone to verify the model number but you can learn alot with sweeps.
Any recommendations on an analyzer?
The Antennas are currently not being used but will be put in service in an EOC. Antennas are commercial grade most are fiberglass Telewave i think. Any recommendations on an analyzer?
