Coax Question
habpatrol
Tulsa, OK
I have a Larsen NMO 800 and need a mount. I have found a Comtelco
MICRO LOSS 900 cable with a NMO mount that I think will work great with my antenna. This is for my vehicle and I will be mostly using my scanner for a 800 mhz trunking system.
My question is will this Comtelco mount do a good job with my Larsen antenna or would it be better to keep Larsen with Larsen.
N
N_Jay
Guest
NMO should be NMO, unless one of the manufacturers is cheating.
selgaran
CM98dn
The Comtelco NMO mount and coax work just fine. I've used one to build a magmount for a WiFi antenna (2.4 GHz), and it works better than the standard Larsen magmount.
