Coax
GKolo
East Tennessee
Is there a company that will put the ends on coax if you order the coax and ends from them without charging you a ton of money ?
I need new coax and have never had much luck with putting the ends on...
GKolo
East Tennessee
Sorry its just the standard connectors, BNC to go into the back of the scanner and PL-249 i think for the antenna.
n5ims
You also didn't mention the type of coax. This factors into what type of connector (not kind of connector like BNC (as an example), but specific model of BNC would be required). It's pretty easy to put a BNC onto RG-6 using standard compression connectors and tools, but putting a BNC onto LMR-400 would require different connector, tools, etc.
K
kb0nly
Guest
I was looking at 9913......
Coax Cable assemblies |RF 50 OHM| RFID Cables | Custom coax assemblies is another one you could consider.
How long of a run? Since this is for a scanner have you considered some RG6 Quad?
The only thing you need to be aware of with the 9913 is seal seal seal!!! Its an air core coax and if you let water get in it becomes a nice piece of water pipe.
I had the stuff for years, many runs, never had problems with it. But i have seen and heard of many with water in their coax. You might want to instead consider foam core instead.
I used some 9913 equivalent on my scanners, Jetstream JT2015F, its a stranded center foam core flexible coax the same size as 9913 with similar loss.
Going to the BNC connector on the larger cable is the problem, they do make a BNC crimp on connector for RG8 sized cable, i know because i have installed one myself, but your better off using a short piece of smaller cable as a strain relief between the scanner and the larger coax. Especially if you use 9913 because its not that flexible and could put a lot of strain on the scanners connector.
You can crimp on an inline SO-239 on the scanner end of the coax, or an inline N Female, and then make a small flexible jumper thats BNC to PL-259 or BNC to N, etc..
As you can tell i have a coax crimper and make stuff like this all the time. A good quality crimper and die set will only set you back about $50 these days, if you make cables a few times a year even its a good investment!
scannerfreak
Well Known Member
Indiana
I would recommend Cable X-Perts as well.
I have purchased many assemblies from them, mostly Andrew CNT-400/600 and they have never let me down :)
GKolo
East Tennessee
I only have about a 60 foot run and that would leave me enough to rearrange the living room too.
I looked at the 9913 because i have used it before and had good luck with it, But if the RG-6 is good i will look at it also.
