Coaxial Collinear Elements
jfriberg
Wausau, WI
I know the number of elements added to a coaxial collinear antenna will increase the gain, but is there a minimum number of elements required for it? Just thinking about total length. This would be for receiving only, no transmit.
zz0468
Banned
I've seen several design variations of coaxial collinear antennas, and they can use 1/4 wave or 1/2 wave elements, and usually a combination of both. So, giving a simple answer with a number isn't really possible...
Consider that a collinear is basically phased 1/2 antennas placed end to end, and that a dipole is a single 1/2 antenna. So, a minimum sized collinear would have 2 half wave sections for 3 db gain. But depending on how you go about it, those two 1/2 antennas could be in 1/4 wave line sections.
All that said, the smallest I've seen is a 1/4 wave section on the bottom, one 1/2 section, then another 1/4 wave section, then a 1/4 wave whip on the top. Is that one element, three elements, or four? See the problem with your question?
