Cobra 45WX - Volume is Loud Even When Turned Down
kingshootr
Lakeside, AZ
So I got all the terminals cleaned on the battery case and the CB is working great - except the volume. Just turning it on, and not turning the knob any further - the volume is blasting - even to this hearing aid assisted listener. The range of turning the knob - the first 1/2 to 2/3 of turning makes no volume difference. The final 1/3rd or so raises the volume a minuscule amount. It's an ooooold dusty relic that, externally at least, has cleaned up nice. Do I need to consider opening it up and try blowing out any gunk that might be in their messing up the volume control (potentiometer?)
WSAC829
Mike Oscar 225
EN64ak
If you know what you are doing it wouldn't hurt. After blowing it out with compressed air, i’d go a step further and carefully spray some contact cleaner in/on both the volume and squelch potentiometers and move them back and forth a few times. Also look closely at them and make sure they are making contact (if they aren’t the sealed style potentiometer). Some times with age and over use the “wiper" wears out and lifts a little to the point where it doesn't make good contact, which is most likely your issue.
Image of potentiometers internals attached.
