code play error
motolover
I unpluged my radio while it was in the middle of programing something. Now when i go to turn it on i get this long beeeep. And when i got to program it, it reads it, then it says Error number 58 has occurred. What can i do to fix it ?
mancow
N.E. Kansas
First of all just for clarification it's codeplug error not code play error or coldplay error :wink:
What type of radio is it, what model?
Usually it's bad juju to interrupt the write cycle to any Moto radio. I've been lucky enough to only brick sabers but they can often be revived with a second attempt.
Maybe if you provide us some more info as to what radio, what software, what speed of computer and what type of inteface then hopefully someon can assist.
Otherwise a trip on the money train to the Moto Depot may be required.
motolover
codeplug sorry. Its a gm300 and im useing rss version R01.00.00. The RSS, computer and interface program my other gm300s fine. So it has to be the radio.
fineshot1
NJ USA (Republic of NJ)
Like mancow said - major nono to interrupt a codeplug write.
Hopefully you have a saved codeplug from this radio from a previous session.
You may be able to revive the radio by retreiving the saved codeplug file and
simply trying to write it to the radio without reading first. It may take it and it
may not but you should try it and see. Good luck
