codeplug used in Portable CPS cannot open in Mobile CPS
Canada
#1
Hi there, I cannot open a .cpg file used in Astro25 Portable CPS for Astro 25 Mobile CPS?
what I should do? someone said open both Portable and Mobile CPS at the same time and use drag and drop, but it is still does not work. CPS R20 ; radio XTS2500. Thanks for your help
N1GTL
CT
#3
You can do a top node drag and drop of the entire code plug between portables and mobiles.
Medford, NJ
#4
You sure you can do that? I think the two CPS versions will let it happen but I would guess there would be a lot of clean up work to do after it's done. I think dragging the meat of the codeplug, your zones, personalities, scan lists one at a time would result in a cleaner transfer.
N1GTL
CT
#5
There are things to clean up. The power settings being one of them and the menus do not copy over but, other than that, I've had good luck. I didn't think you can drag or cut/paste personalities in Astro. I know you can export things out to a pick list and then import.
#7
Top node drag and drop is fully supported in the Astro25 CPS except for most instances of FPP flashed portables, they require special handling.
The CPS does come with a very nice tutorial video, or you can call Motorola support IF YOU HAVE A LEGAL COPY OF THE SOFTWARE.
