Colorado Springs
Mick
Western U.S.
Hello! For the Colorado Springs (Dept of Telecom) System at
http://www.radioreference.com/modules.php?name=RR&sid=2877
it looks like a new frq. was just added, 866.55.
While visiting last month it seemed like the first two frqs. listed, 854.1125 and 854.2875, were just conventional channels. The other frqs. are licensed to other TRS's with numerous other frqs.
Has someone confirmed this (Dept of Telecom) System is in use? Thanks in advance!
Colorado
Follow-up...
I've had this freq programmed in for awhile now, and I haven't seen any traffic on it. Either it's not in use, or it's not used by any TG's that I listen to.
