Columbus Police
oesjmr
Pickerington, OH
I'm still receiving CPD fine. I listen mostly to Zone 2, but I just flipped to the other zones and hear traffic.
oesjmr
Pickerington, OH
I forgot to mention that last week I heard a message on Zone 2 for cars that didn't have reprogrammed radios to go to 9 sub for programming. I'm guessing that means the switch it MARCS-IP isn't too far off.
KD8DVR
Columbus, Ohio
No, the reprogramming was for some other issue. It ended up messing up some radios and they had to go back to have them diagnosed.
wa8pyr
Staff member
Lead Database Admin
Ohio
Heard some testing on the new Columbus P25 system tonight, TG 57271, Zone 3 dispatch.
Meh. Signal from my house is only so-so.
Pedalfar1
Columbus, Ohio
Zones 2 and 4 that I monitor seem to be back on my radio (BC296D). Days seemed to be numbered before the switch. Certainly for my old radio monitoring CPD. Trying to decide if I give up listening to CPD and just continue to monitor COIRS once the change happens.
W8RMH
Feed Provider Since 2012
If you can receive COIRS you should be able to receive the Columbus system as it uses 800 MHz. even though it is tied into MARCS-IP.
Pedalfar1
Columbus, Ohio
<< If you can receive COIRS you should be able to receive the Columbus system as it uses 800 MHz. even though it is tied into MARCS-IP. >>
I receive COIRS (Dublin, Hilliard, NW EMS) loud and clear here in Dublin. So when CPD goes digital it'll be on 800 MHz and not 700. Wow. Didn't realize this. Because if it goes 700, my BC296D will not work.
KD8DVR
Columbus, Ohio
The MARCS-IP Franklin County system is a combination of 700 and 800 Mhz frequencies. You'd be out of luck, if they use this system as currently configured.
KD8DVR
Columbus, Ohio
Perhaps I was mistaken.. the "columbus City" system is all 800 Mhz. It's up to 11 frequencies now.
