MacombMonitor
- Joined
- May 18, 2005
- Messages
- 3,551
My COMET SMA-501 Mini-Antenna arrive from Universal Radio! I have it attached to my tiny Icom IC-R2 communications receiver...makes for a very compact monitor radio while out, and about! The radio itself is only 3.5" H x 2.25" W x 1" D. The original supplied antenna is 7" tall! The COMET SMA-501 is only 1.75" H x .5" DIA. As you can see, the combination of the R2, and the SMA-501 is very small. What's really amazing is how well it performs! I've checked it on 2M Ham (144~148MHz), 150, 450, and 850MHz bands. I live in Macomb Township, Michigan, and sitting in my house, I can pick up everything around me that I normally monitor (with the exception of digital of course, due to limitations of the R2). I can even hear Warren, Michigan Public Safety (850MHz), which is 19 miles South of me! Some people have referred to these mini-antennas as being nothing more than a dummy load. Maybe for transmitting they don't perform well, I haven't tried, but for a receiver/scanner, I'm very satisfied!
Having an SMA mount, this antenna will work on the newer Uniden BCD396T, and BR330T. Something you might want to check out, if your monitoring is somewhat local.
