Trying to run two different scanners on same computer using Proscan. Both instances of Proscan are in separate directories and working fine. I want to stream both scanners but not enough comm ports. Can I use a multiport USB plugged into a single USB port in the computer thereby adding comm ports? Need one comm port for each scanner to communicate and additional comm ports for the USB sound cards. Does this make sense?
