Communication error when trying to program Vertex VX-354?
indians9286
Hello,
I am very sorry if I am not posting this question in the right forum! I just bought a Vertex VX-354 and software with cable. The software I am using is CE86 for windows. When I try uploading/downloading, it says switch radio on, then start uploading. Then a message pops up saying "Communication error". Did this happen to anyone else? I need some help on trying to fix it. I also set the configure settings to the right settings. Any help would be greatly appreciated.
kb32
Hello,
I changed the COM port in the device manager then changed the COM port in CE86 to the same as the device manager and it worked nicely.
