NMO27 is your standard HD, but low-performing choice.
NMO34 + W640 whip & Springb if you want to play in what’s today possible, given an AM/SSB radio with NRC.
27 will do what’s shown as ground wave to about 1/4—1/3. 34 will do nearly all of what’s shaded.
Height is Might.
That two feet is a substantial penalty to overcome even assuming roof-center mount.
1-2/mile average against 3-5/miles or better in
heavy metro, same conditions.
5’ whip is the minimum to be able to say, “My vehicle is equipped with Citizen Band”, not a walkie-talkie.
The other men out there have poor rigs — it is to be assumed — and the job of one’s own is to tackle that shortcoming.
Said another way,
Height is Time, as everyone is fast moving away from each other.
May only have one chance.
I run an antenna in city on my pickup roof that meets 13’. When it encounters obstacles, it flexes away. No spring.
It’s a 7’ no-compromise choice.
34 w/spring is going to shrug off most every hit. For years. 90% of what mine’ll do, is the guess. But low-key & higher QC.
The short antennas are so low performing that on roads I travel 10,000+ miles per month it’s a shock that my (previous) rental car radio rig picked up nothing along Interstates I know as to the Where, When, Why & How which is operative at that hour of a weekday.
Ever hear others say, “CB is dead”? This is why: poor antenna design, mount & location. (The radios available just the last couple years changed the whole game; but antenna still first). This is past poor installation.
Great Install
Great Radio
Great External Speaker
Lousy Antenna Choice.
The first three can’t overcome the problem of not being able to,
Hear, and Be Heard.
A fiberglass antenna has no give. Requires a potential pair of failure points (spring). NMO antennas built to a different standard. Can take the hits reasonably well. Remove? Buy the optional cover cap to screw into place.
If my garage had 3.5’-4.0’ clearance to my vehicle I’d choose the 5’ tall 34 without a second thought.
The point to having this radio service is otherwise a missed target without right antenna (right location).
