Compatible PC Software
Hearken
#1
Will the TRX-1 and TRX-2 EZ Scan PC software work with each other? Instead of downloading two separate EZ Scan software's on the PC, I was curious if downloading the TRX-2 only and using it on the TRX-1. Has anyone tried this or knows it may work or not?
Hearken
#3
Thanks buddrousa
Thanks for clarifying the PC software, one less problem makes life easier to live.
AggieCon
Texas
#4
Keep in mind, though, that you can archive the v-scanner folder in one version and then import it in the other. You don't have to make your scanlists twice.
