BCD325P2/BCD996P2: Complete scanner list?
monkster
Bull Shoals Arkansas
I have been trying to program this scanner with Freescan since Christmas. I get some of my entries to show up but not all. I'm in Arkansas and trying to put Baxter and Marion counties and want to add the local businesses as well. I would like to add the local business frequencies as well but can't find a list for them. Any ideas on where to get the right files for this? It would be great to scan everything available for my area but just lost on where to find everything.
fxdscon
¯\_(ツ)_/¯
Have you checked the database here on Radio Reference?
u2brent
OAMPT
KRWDPAXKRS1
Have you looked here?
:unsure:
monkster
I have put data in for Baxter County and now want to add more files but i am getting this msg in Freescan this file indicates version Frequency Output and is not compatible with this version of Freescan.
hiegtx
Dallas, TX
What frequency, or agency (business?) are you trying to enter when that error mesage comes up?
hiegtx
Dallas, TX
It's a group of frequencies in a csv file but it won't upload.
Can you post the file? You'll probably have to either zip the file, or change the file extension, as I don't think that *.csv is a valid extension for attaching to a post.
Either zip the file with Winzip, or the free 7Zip, or change the file extention to one that is allowed. For an example, if your file is named "myfile.csv", either change that to "myfile.txt" or "myfile.csv.txt" so that it can be attached.
Also, in your *.csv file, check for for any extra spaces in the frequency. As an example, frequency "461.500" would be valid, but " 460.500" would not be (note the extra blank space before the frequency. That would easily be overlooked in a spreadsheet (*.csv) file, but would cause FreeSCAN to treat it as invalid).
monkster
I have posted a copy of the file I want to upload. But seems Freescan won't recognize this file type. Is there a way to convert it to a file it will recognize for uploading? I have been using Radioreference to paste to my scanner but not all information available is uploadable. An example would be a listing of all CB and frs frequencies as there are many hunters and fishermen that use these channels to communicate. Thanks
  • ctid_110 (business .zip
hiegtx
Dallas, TX
While FreeSCAN is not set up to allow the direct import from a *.csv file, you can use FreeSCAN's E-Z Grab tool to do this.
Start FreeSCAN
Once FreeSCAN us up on screen, you should basically have a blank screen, unless you already have a file open.
Whether you already have one in progress, or not, click on the "New System" icon. That's the fifth one on the second line (under the menu line). If you wanted to, instead, start a new file, then click on the icon of a blank sheet of paper (the first one on the second line).
78856
Now, go to your spreadsheet, in Excel, or whatever other program you are using.
In your spreadsheet. Hold down the <CTRL> key and click at the top of the columns you want to import. Some of them will not match to a field in FreeSCAN. I selected the Frequency, the Alpha Tag, and PL columns.
I have attached the file this created. Note that you have a number of frequencies in your list that are in the 850MHz range. Those would be frequencies for a trunked system, and would not be entered in a conventional system.
78859
Now, copy those columns to the Windows Clipboard. Either <Right Click> and choose Copy from the pop-up menu, or use the shortcut <CTRL>+<C>.
Now, go back to FreeSCAN and click in the New System you are using (either new, on a new system, with no other data, or adding a New system to an existing file).
Click on the E-Z Grab icon in the system.
78858
That gets you here:
78860
Click on the Copy from Clipboard button.
That pulls the selected columns to the clipboard, where you can access them from FreeSCAN.
For the columns that you intend to import, update the name from "Ignore" to whichever field it needs to go in FreeSCAN.
78862
The first field (from your spreadsheet) is Frequency
The second (input freq.), third (FCC Callsign), & fourth (Agency) are not used.
The fifth, 'Description' in your spreadsheet would be used in the Comment field in FreeSCAN.
The sixth is the Alpha Tag, so that maps to Name. The seventh would map to the Tone column.
78863
Once you have the column names matched up, click the Import into FreeSCAN button on the E-Z Grab window.
And there it is:
78864
Remember that FreeSCAN does not correctly support DMR. You cannot set a Color Code. FreeSCAN also does not recognize the DMR frequencies that were imported as being Digital. And the software has no support at all for NXDN.
ProScan does support both DMR & NXDN, and you can do a similar "select & import the fields" process in it as well.
  • monkster.zip
monkster
hiegtx Thank you so much for this walkthrough! This help is better than any class I could take and I know how much time this took to put together. I am using this info remembering and appreciating your effort. Again Thanks..
