Computer Question
Thayne
This is a computer problem I would like to fix if possible. I have a wired ethernet network that consists of five computers, three running XP and 2 running Win 98 & DOS.(Because I still need them to run old programming software)
I have Adobe Acrobat 7 only on the one fast XP computer; that also has the laserjet that will print on both sides, etc. I can share Acrobat over the network with all the XP machines, but I think I need a driver for win 98 but I cannot find anything on the Adobe or Microsoft sites or on the Win 98 cd.
The reason is that sometimes I need to print from some of those old programs that will not run on XP. (Maybe this is not possible because Acrobat 7 will only run on XP)
Any ideas?
DickH
Any ideas?
Here is my idea. Copy the text in a document in the old program, then paste it into a document generated in a new program.
Dick
DickH
Dick
If you have trouble when you paste it into the new document, try this. In the EDIT menu, click "paste special". That will give you a couple of choices.
Dick
Thayne
That would work except ANY program on the win 98 machines won't print to Acrobat on the XP computer running Acrobat. One thing that works but is a lot of trouble is printing to a file then sending the file to the other computer over the network.
Thanks for Responding anyway!
Al42
Long Island, NY, USA
Exactly what programs are we talking about? And what file formats? The solution will be different for different situations.
Thayne
Yep, that is probably why no driver seems to exist for Acrobat 7 that would work for Win 98.
Thanks for the replies, everyone.
