moonies said:if that is the range of your listening request then try the austin spectra which is a mag-mount and works VERY well!!!!!
mlevin312 said:I saw this antenna on Scanner Master, does anyone use it and if so how well does it work? I'll be using it on a mag mount with my psr 500 to monitor from 151 mhz up through 800 mhz?
Any info would be appreciated.
The Spectra is the farthest thing you can get from "low profile" or discrete! It is a monstrosity. And mine (on a mag mount) doesn't work any better than my stock rubber duck. Eighty bucks wasted, if you ask me.moonies said:if that is the range of your listening request then try the austin spectra which is a mag-mount and works VERY well!!!!!
af5rn said:The Spectra is the farthest thing you can get from "low profile" or discrete! It is a monstrosity. And mine (on a mag mount) doesn't work any better than my stock rubber duck. Eighty bucks wasted, if you ask me.
Melvin, if "low profile" is your overriding concern, if the rubber duck won't do the job, and if for some reason you cannot go with a true undercover antenna ( http://www.sti-co.com/ ), then personally, I'd go with a glass mount, cellular look-alike scanner antenna, also available from Scanner Master. It works well in an urban or suburban environment (with relatively close system proximity), and it's about the closest thing you can get to "low profile" for surveillance work.
See ---> http://www.radioreference.com/forums/showthread.php?t=104517n5tkn said:I've considered running a duplexer to run separate antennas, if I can find one that will do the necessary frequencies. Any recommendations along that line would be helpful.
mlevin312 said:Atuually I am looking for something "low profile". I do surveillance work and it will be mounted on the trunk.
pappy1 said:I use the license plate antenna and it works great and range is almost as good as the stinger I used before.
You can get it here: http://www.licenseplateantenna.com/
