RS Pro2096
Any of the newer ones will work with DMR, BUT.... Uniden you have pay extra for DMR. Whistler scanners you don't. *there are arguments on if Whistler can follow certain trunked DMR systems and Uniden does a far better job. The forums are filled with those comments for both scanners. I have a WS1080 and when they added DMR upgrade at no cost, it worked fine. Then they added several firmware updates and it quit working like it did originally but that was only for one system at O'hare Airport in Chicago. If the system is one DMR frequency It does pretty well as long as you're within the SITE coverage maps of your Sheriff's tower. You're in luck as most people are SELLING their older scanners to get the new SDS 100 from Uniden in the Classifieds section of RREF above. I'm sure you can find one cheap enough that has DMR if you look.
