Connecting RadioReference to an internet radio.
redfoxone
UK
Hi, this is my first post. So sorry if it’s in the wrong place.
What I want to know is. Can you stream live commentary from RadioReference straight to an internet radio?
and if so, how please.
Thank you.
redfoxone
UK
Thank you for your reply OH1063.
What I am asking is, instead of listening via the computer, I want (if possible) to listen through my internet radio .
PeterGV
K1PGV
Mont Vernon, NH
To answer the OP's question: Yes, you can listen to RR Feeds directly on your Internet radio.
There are multiple ways to do this. One is to use an application (like the one for the SqueezeBox... I don't recall its name) that makes this easy.
The OTHER way to do this is to directly access the URL associated with the RR feed from your Internet Radio. The problem with the direct access approach is (a) RR doesn't appreciate direct connections to URLs... I'm not sure if it's a Terms of Service violation or not, but I *do* know it's discouraged, (b) The URL isn't deliberately made public by RR so you have to find it yourself, (c) The URL can change over time.
Peter
K1PGV
redfoxone
UK
Thank you scannerbox for your suggestion on this subject, but sadly the wifi radio that I have isn’t a squeezebox wifi. But I look into your ideas
mattl3320
pa
squeeze box radio ?
can anyone tell me if i can program the squeeze box radio with the enthernet port that is on the back with the port on my computer just bought one and want to add the scannerbox app to it this way. any help please i do have a wireless internet connection but i like to program with the cables instead thank u.
K
kb0nly
Guest
No...
You have to have the Squeezebox server running on a computer, and the Squeezebox connected to your network. You could connect the computer and Squeezebox to an ethernet hub or switch to accomplish this but you still need internet to the Squeezebox at the same time. So what your asking, just connecting them together, not going to work.
If by wireless you mean you have Wifi then no problem, connect the Squeezebox to your wireless network, install the server application on your computer, and then follow the tutorial on the Scannerbox website to install.
mattl3320
pa
ok i have a verizon wireless modem that i use for wifi will this work? if so i run the program for scanner box and that it right. after connecting to my network.
mattl3320
pa
need help getting the scannerbox app to work the wireless connection is working able to play my own music in the rest of the house from the list on the computer . tryed the steps in the install guide and everything looks good but when i go to look in the radio for scannerbox under app insteller their is nothing. i even double check the url that i was giving and nothing works and help please. and the box for the thing in app installer is u check.
scannerbox
michigan
Double check that the URL entered into the Squeeze Center server software is actually getting saved when you hit the Apply button. Also, make sure that computer can get on the internet.
Take a look at ScannerBox.us - Streaming live audio feeds to Logitech Squeezebox Radio and if you still can't get it to work send the support email on the page a message and I will take a look.
redfoxone
UK
I would like to thank everyone for their input, especially Richard for walking me through the procedures of this issue.
