Connection Issues
Litchfield Illinois
#1
I have been dealing with this for quit some time. I have switched router, I have worked on network issues, and can't seem to get reliable feed? I was thinking it might be ISP issues but proving that it seeming to be hard. Woke up this morning to it saying "Source Client - Broadcastify Timeout"?
n0nhp
Grand Junction
#2
There have been others with the same kind of problem. Here are some of the threads:
https://forums.radioreference.com/b...tion/338705-audio-3-server-going-down-up.html
https://forums.radioreference.com/b...ps-going-down-pingplotter-interpretation.html
And there may be links to other older threads.
Read through and try running a ping-plotter type program for a while. There is a very good chance that your ISP is having dropouts with their connections that will not show up on TCP but kill the UDP that our audio uses.
Good Luck
Bruce
flythunderbird
Grid square EM99fh
#3
I had a similar problem a couple of years ago. The cable company rolled a truck and the technician replaced the connectors in the house, which didn't fix it. I had previously run PingPlotter on it, so I gave the results to the technician ... he called his supervisor to discuss the PingPlotter results, and the supervisor told him to replace the connectors out on the pole. One of the connectors on the pole had gotten water in it, causing the disconnect issues.
