MindenJoe
Hi everyone, I picked up an old Connex CX 4400 HP with an external frequency counter. I want it for only 10 meters but somewhere in it's history it was converted to include 11 meters. Going through the frequencies, I noticed that it's missing all of the upper frequencies on ten meters and also has frequencies below the 10 meter band. Looking on the Web, I see that the original mod had you remove a resistor and change the jumpers on J29 and I believe J27. I'm looking for which resistor to solder back on the board, and the original configurations of the jumpers. It does transmit and receive but with massive feed back on TX when I listen with a radio on the other end of the house. You hear very little voice and a lot of feedback. It was putting out close to 30 watts, so I turned it back down to the the factory setting of 10 watts max. I also noticed that the AM modulation pot was turned all the way up, so I turned it way down. It appears to be on frequency but looks like someone went at the pots with a screwdriver. I guess they thought more watts on the meter meant more power. Any help or suggestions would be appreciated.
