Console database manager (cdm)
When you look at a CDM you can select a CCI Port and it will display the associated CEBs.
However, I am trying to reproduce this relationship through the raw data tables. Unfortunately, I cannot see a way to do this.
The table OPERATOR POSITION contains a OPID field which represents each CCI Port.
The table CEB table has a CEB ID field.
However, I cannot work out how you form a relationship between the CEB ID and the OPID?
I have tried various ways such as by looking at the AMBASSADOR card a CEB is connected to but I still dont find a way of tunnelling through to the OPID.
Does anyone out there know how in the raw data tables they can be linked?
All help most appreciated.
